# Page Not Found
The URL `basics/audiobook-mastering` does not exist. This page may have been moved, renamed, or deleted.
## Suggested Pages
You may be looking for one of the following:
- [Audiobook Mastering](https://support.audacityteam.org/audio-editing/audiobook-mastering.md)
- [Editing audio](https://support.audacityteam.org/basics/audacity-editing.md)
- [Customizing Audacity](https://support.audacityteam.org/basics/customizing-audacity.md)
- [Downloading & installing Audacity](https://support.audacityteam.org/basics/downloading-and-installing-audacity.md)
- [Sharing audio online](https://support.audacityteam.org/basics/sharing-audio-online.md)
## How to find the correct page
If the exact page cannot be found, you can still retrieve the information using the documentation query interface.
### Option 1 — Ask a question (recommended)
Perform an HTTP GET request on the following URL with the `ask` and `goal` query parameters:
GET https://support.audacityteam.org/audio-editing/audiobook-mastering.md?ask=<question>&goal=<user_goal>
`ask` is the immediate question: it should be specific, self-contained, and written in natural language.
`goal` is what the user is ultimately trying to achieve, the reason they need the answer. Sharing it helps GitBook give you a better, more relevant answer. A goal is most helpful when it describes the outcome the user wants rather than restating the question. For example, with `ask=how do I create an API token`, a goal like `automate deployments from our CI pipeline` lets GitBook tailor the answer to that use case.
The response will contain a direct answer to the question and relevant excerpts and sources from the documentation.
### Option 2 — Browse the documentation index
Full index: https://support.audacityteam.org/sitemap.md
Use this to discover valid page paths or navigate the documentation structure.
### Option 3 — Retrieve the full documentation corpus
Full export: https://support.audacityteam.org/llms-full.txt
Use this to access all content at once and perform your own parsing or retrieval. It will be more expensive.
## Tips for requesting documentation
Prefer `.md` URLs for structured content, append `.md` to URLs (e.g., `/audio-editing/audiobook-mastering.md`).
You may also use `Accept: text/markdown` header for content negotiation.
