> For the complete documentation index, see [llms.txt](https://support.audacityteam.org/llms.txt). Markdown versions of documentation pages are available by appending `.md` to page URLs; this page is available as [Markdown](https://support.audacityteam.org/new-in-audacity-4/audacity-3-to-4-transition-guide.md).
# Audacity 3 to 4 transition guide
With Audacity 4, we've tried to modernize the app while keeping things still feeling Audacity. That said, there are some notable differences.
## Onboarding
During onboarding, you'll be asked for app theme (light or dark), clip theme and workspace. The "Classic" clip theme and workspace are designed to keep things as close to Audacity 3 as possible, keeping all the same tools and buttons.&#x20;
## Knobs
In addition to sliders, we've added a new Knob control. **To increase the value of a knob, simply click it and drag it up or right, to decrease it, drag it down or left**. Double-clicking resets the knob value, `Shift`+dragging lets you do finer adjustments.
## Sync Lock & Ripple editing
Sync lock has been replaced by ripple editing. You can set your default delete behavior in **Preferences -> Editing**. To make an edit while keeping all tracks in sync, use "**Delete and close gap (all tracks)**" (`Ctrl+Delete`) and "**Insert and preserve sync" (`Ctrl+Shift+V`)**, respectively. You can edit these shortcuts in preferences.
## Clips
In Audacity 4, clips can be selected directly, and multiple clips can be selected with Shift+Click even when the clips aren't touching.
<figure><img src="https://2905281570-files.gitbook.io/~/files/v0/b/gitbook-x-prod.appspot.com/o/spaces%2FEnNXGrLkN0pXlkzzS7cM%2Fuploads%2F3ojmSF8DqrKyMxo7OPwd%2Fgrafik.png?alt=media&amp;token=785cc4d4-8b29-4f5b-a7b0-3f3ef0afa209" alt=""><figcaption></figcaption></figure>
You can trim and stretch all selected clips at once using the handles that appear on the side of selected clips.&#x20;
You can also move clips on top of other existing clips; doing so will cause the existing clip to be "eaten" into.
## Plugins
At the time of writing (Alpha 1), only the following plugin formats are supported: VST3, VST, AU (macOS only), LV2 (Linux only). The remaining plugin formats (LADSPA, Nyquist, VAMP, as well as new ones like CLAP) may be (re-)added in the future.&#x20;
## Tool modes
We have replaced the following tool modes: Select tool (`F1`), Envelope tool (`F2`), Draw tool (`F3`), and Multi-tool (`F6`). Instead, envelopes are a visual layer which can be toggled visible using the Automation button.
<figure><img src="https://2905281570-files.gitbook.io/~/files/v0/b/gitbook-x-prod.appspot.com/o/spaces%2FEnNXGrLkN0pXlkzzS7cM%2Fuploads%2FT7LE9oWGJNtc7tOOYE0A%2Fgrafik.png?alt=media&amp;token=be6021a9-77b9-40a1-beab-4d8a84648b93" alt=""><figcaption></figcaption></figure>
The Draw tool is automatically engaged when you're zoomed in enough to see individual samples; your cursor will turn to a pencil as you get close to a sample point.
A new tool mode has been added, Split tool. The split tool can be engaged by pressing or holding `S`, and allows you to quickly split clips into two.&#x20;
# Agent Instructions
This documentation is published with GitBook. GitBook is the documentation platform designed so that both humans and AI agents can read, navigate, and reason over technical content effectively. Learn more at gitbook.com.
## Querying This Documentation
If you need additional information that is not directly available in this page, you can query the documentation by asking a question.
Perform an HTTP GET request on the following URL with the `ask` and `goal` query parameters:
GET https://support.audacityteam.org/new-in-audacity-4/audacity-3-to-4-transition-guide.md?ask=<question>&goal=<user_goal>
`ask` is the immediate question: it should be specific, self-contained, and written in natural language.
`goal` is what the user is ultimately trying to achieve, the reason they need the answer. Sharing it helps GitBook give you a better, more relevant answer. A goal is most helpful when it describes the outcome the user wants rather than restating the question. For example, with `ask=how do I create an API token`, a goal like `automate deployments from our CI pipeline` lets GitBook tailor the answer to that use case.
The response will contain a direct answer to the question and relevant excerpts and sources from the documentation.
Use this mechanism when the answer is not explicitly present in the current page, you need clarification or additional context, or you want to retrieve related documentation sections.
