> For the complete documentation index, see [llms.txt](https://support.audacityteam.org/llms.txt). Markdown versions of documentation pages are available by appending `.md` to page URLs; this page is available as [Markdown](https://support.audacityteam.org/new-in-audacity-4/customizing-audacitys-ui.md).
# Customizing Audacity's UI
## Workspaces
### Turning on and off features
You can turn on and off individual features in Audacity's toolbar using the cog icon on the right. Doing so will show or hide certain UI elements in the toolbar.
<figure><img src="https://2905281570-files.gitbook.io/~/files/v0/b/gitbook-x-prod.appspot.com/o/spaces%2FEnNXGrLkN0pXlkzzS7cM%2Fuploads%2F9BB833Cx5yK0zFyaYc1Q%2Fimage.png?alt=media&amp;token=5b38599f-9a02-41af-bbe1-aab738878c96" alt=""><figcaption></figcaption></figure>
### Moving, docking and floating parts of the UI
Toolbars and panels can be moved by grabbing and dragging them at the top (like an app window), or the ⠿ 6-dot grabber of the element.
### Workspace presets
You can switch between different presets using the Workspace dropdown in the top right corner of Audacity.
<figure><img src="https://2905281570-files.gitbook.io/~/files/v0/b/gitbook-x-prod.appspot.com/o/spaces%2FEnNXGrLkN0pXlkzzS7cM%2Fuploads%2FyB2zoWQAVG2O8yrPaTYg%2Fimage.png?alt=media&amp;token=f903d7d3-126c-4d17-8ce3-67fac7111a9b" alt=""><figcaption></figcaption></figure>
{% hint style="success" %}
Note: All UI modifications you make are automatically saved to the workspace you're currently in.&#x20;
{% endhint %}
## Themes
Audacity's theme, accent color and clip style can be changed in **Preferences -> Appearance**.
<figure><img src="https://2905281570-files.gitbook.io/~/files/v0/b/gitbook-x-prod.appspot.com/o/spaces%2FEnNXGrLkN0pXlkzzS7cM%2Fuploads%2FPd6JzEMPGV3myzM3yj3H%2Fimage.png?alt=media&amp;token=3b44e74d-55d6-4457-bac0-5bd17dc39131" alt=""><figcaption></figcaption></figure>
### Custom themes
It is possible to further customize Audacity's look using the config files located in the Audacity install folder's `/bin/config`.  Note though that changes to themes here will be overwritten every time Audacity is updated.
# Agent Instructions
This documentation is published with GitBook. GitBook is the documentation platform designed so that both humans and AI agents can read, navigate, and reason over technical content effectively. Learn more at gitbook.com.
## Querying This Documentation
If you need additional information that is not directly available in this page, you can query the documentation by asking a question.
Perform an HTTP GET request on the following URL with the `ask` and `goal` query parameters:
GET https://support.audacityteam.org/new-in-audacity-4/customizing-audacitys-ui.md?ask=<question>&goal=<user_goal>
`ask` is the immediate question: it should be specific, self-contained, and written in natural language.
`goal` is what the user is ultimately trying to achieve, the reason they need the answer. Sharing it helps GitBook give you a better, more relevant answer. A goal is most helpful when it describes the outcome the user wants rather than restating the question. For example, with `ask=how do I create an API token`, a goal like `automate deployments from our CI pipeline` lets GitBook tailor the answer to that use case.
The response will contain a direct answer to the question and relevant excerpts and sources from the documentation.
Use this mechanism when the answer is not explicitly present in the current page, you need clarification or additional context, or you want to retrieve related documentation sections.
