> For the complete documentation index, see [llms.txt](https://support.audacityteam.org/llms.txt). Markdown versions of documentation pages are available by appending `.md` to page URLs; this page is available as [Markdown](https://support.audacityteam.org/special-uses/expected-uses.md).
# Expected uses
Audacity is an audio editor with limited DAW functionality. As such, we expect and test for the following uses:
* Recording audio, including digitizing analog media
* Applying effects to alter or enhance audio
* Installing plugins to extend Audacity's functionality
* Analyzing audio
* Producing podcasts, audio books, songs, and other audio works
* Saving projects to disk or the audio.com cloud
* Exporting projects into various file formats.
## Unsupported uses
Audacity can be used in a wide variety of other scenarios as well. However, while we appreciate you finding more uses for Audacity than we initially anticipated, these scenarios are untested, and you may use them at your own risk:
* Using Audacity as a HEX editor.
* Using Audacity with non-audio files ("data bending").
* Using a cloud sync service other than audio.com for open projects. This is due to Audacity's project format creating [temporary files](https://sqlite.org/wal.html) as part of its normal operations, which generic cloud sync services may struggle with syncing adequately. As a result, the use of cloud services other than audio.com may result in data corruption.
* Using Audacity on legacy operating systems. While we don't explicitly add any checks to artificially limit systems on which Audacity can run on, we also don't test compatibility with it.
* Using self-compiled or altered versions. Audacity is widely re-distributed by third parties, with some opting to disable certain features or apply certain changes. We only test the builds available on [audacityteam.org](https://audacityteam.org/).
# Agent Instructions
This documentation is published with GitBook. GitBook is the documentation platform designed so that both humans and AI agents can read, navigate, and reason over technical content effectively. Learn more at gitbook.com.
## Querying This Documentation
If you need additional information that is not directly available in this page, you can query the documentation by asking a question.
Perform an HTTP GET request on the following URL with the `ask` and `goal` query parameters:
GET https://support.audacityteam.org/special-uses/expected-uses.md?ask=<question>&goal=<user_goal>
`ask` is the immediate question: it should be specific, self-contained, and written in natural language.
`goal` is what the user is ultimately trying to achieve, the reason they need the answer. Sharing it helps GitBook give you a better, more relevant answer. A goal is most helpful when it describes the outcome the user wants rather than restating the question. For example, with `ask=how do I create an API token`, a goal like `automate deployments from our CI pipeline` lets GitBook tailor the answer to that use case.
The response will contain a direct answer to the question and relevant excerpts and sources from the documentation.
Use this mechanism when the answer is not explicitly present in the current page, you need clarification or additional context, or you want to retrieve related documentation sections.
