# Making crossfades
## Crossfading Clips
If you have two clips in one track you'd like to crossfade, you can use **Crossfade Clips** effect. To use it:
1. Have two clips in one track.
2. Select the region you'd like to apply the crossfade to. Try to select roughly the same amount of time in both clips.
   ![](https://2387260374-files.gitbook.io/~/files/v0/b/gitbook-x-prod.appspot.com/o/spaces%2F-MhmBVzGzh8SctWQ6jPR%2Fuploads%2FBgf59L22pBdxSDzUIbwx%2Fimage.png?alt=media\&token=0b59da00-215b-4efe-9b5a-a18dc661fadd)\
   **Note:** Any empty space between the clips will be automatically removed and ignored in the crossfade.&#x20;
3. Use **Effects > Fading > Crossfade Clips** to crossfade the clips.&#x20;
## Crossfading between Tracks
To crossfade between tracks, use the following steps:&#x20;
1. Position the clips on the tracks so that they overlap in the range you want to crossfade, and select the audio in the overlapping region in both clips:
   ![](https://2387260374-files.gitbook.io/~/files/v0/b/gitbook-x-prod.appspot.com/o/spaces%2F-MhmBVzGzh8SctWQ6jPR%2Fuploads%2FyQX33UTXXGXuyu6zdwSn%2Fimage.png?alt=media\&token=8fc8d988-4e4c-4067-b8e4-1628a437fd5b)
2. Use **Effects > Fading > Crossfade Tracks** to crossfade the tracks.\
   ![](https://2387260374-files.gitbook.io/~/files/v0/b/gitbook-x-prod.appspot.com/o/spaces%2F-MhmBVzGzh8SctWQ6jPR%2Fuploads%2FWQpZ6wzymLJ9uKiydAZj%2FCrossfade%20Tracks.png?alt=media\&token=e1d46459-04ad-4861-bfc8-de87eb2c3ea2)
