# Making crossfades
## Crossfading Clips
If you have two clips in one track you'd like to crossfade, you can use **Crossfade Clips** effect. To use it:
1. Have two clips in one track.
2. Select the region you'd like to apply the crossfade to. Try to select roughly the same amount of time in both clips.
   ![](/files/wCFe09AKLdbqkxALc0Yo)\
   **Note:** Any empty space between the clips will be automatically removed and ignored in the crossfade.&#x20;
3. Use **Effects > Fading > Crossfade Clips** to crossfade the clips.&#x20;
## Crossfading between Tracks
To crossfade between tracks, use the following steps:&#x20;
1. Position the clips on the tracks so that they overlap in the range you want to crossfade, and select the audio in the overlapping region in both clips:
   ![](/files/9J6uGANef1HsoS8Nj5fN)
2. Use **Effects > Fading > Crossfade Tracks** to crossfade the tracks.\
   ![](/files/NE05rA2Z14QDWUR0sPun)
# Agent Instructions: Querying This Documentation
If you need additional information that is not directly available in this page, you can query the documentation dynamically by asking a question.
Perform an HTTP GET request on the current page URL with the `ask` query parameter:
GET https://support.audacityteam.org/~/changes/gvJiM3Yz1dG3uk35ImQU/audio-editing/making-crossfades.md?ask=<question>
The question should be specific, self-contained, and written in natural language.
The response will contain a direct answer to the question and relevant excerpts and sources from the documentation.
Use this mechanism when the answer is not explicitly present in the current page, you need clarification or additional context, or you want to retrieve related documentation sections.
