> For the complete documentation index, see [llms.txt](https://support.audacityteam.org/llms.txt). Markdown versions of documentation pages are available by appending `.md` to page URLs; this page is available as [Markdown](https://support.audacityteam.org/audio-editing/changing-pitch.md). Agents can also search and read this documentation through its [MCP server](https://support.audacityteam.org/~gitbook/mcp).
# Changing pitch
Audacity can make audio sound higher or lower
## Changing pitch per clip
You can change the pitch of a clip by selecting the clip, and then pressing **Alt+↓↑** to change the pitch by a semitone. Alternatively, you also can click on the overflow menu (...) in the top right of the clip, and then **Pitch and Speed...** to change it via a dialog. You can also use the dialog to change the pitch by cents instead of just semitones.
Once you have changed the pitch, the clip will have an indication of how much it's been changed:
<figure><img src="https://2387260374-files.gitbook.io/~/files/v0/b/gitbook-x-prod.appspot.com/o/spaces%2F-MhmBVzGzh8SctWQ6jPR%2Fuploads%2FEeJgYGC4ZQLl0pxpORGx%2Fimage.png?alt=media&amp;token=b2dc3c11-e008-416b-82c2-f3733e9e6911" alt=""><figcaption><p>The clip pitch indicator shows that the pitch has been raised by 4 semitones.</p></figcaption></figure>
You can change pitch at any time by clicking on the indicator, or reset it by `Ctrl`+clicking it (macOS: `Cmd`+clicking) .
## Pitch correction of an entire track (Auto-Tune)
While Audacity does not have any pitch correction natively, you can use plugins such as [MuseFX PitchFix](https://www.musehub.com/) for this task. See [Using master effects & realtime effects](https://support.audacityteam.org/audio-editing/using-realtime-effects.md) and [Installing plugins](https://support.audacityteam.org/basics/customizing-audacity/installing-plugins.md)on how to use these plugins.
## Changing pitch for an arbitrary audio selection
{% hint style="warning" %}
**Caution:** This method permanently alters the audio data and cannot be changed later.
{% endhint %}
To change the pitch of an arbitrary selection of audio, go to **Effects -> Pitch and Tempo -> Change Pitch**.
# Agent Instructions
This documentation is published with GitBook. GitBook is the documentation platform designed so that both humans and AI agents can read, navigate, and reason over technical content effectively. Learn more at gitbook.com.
## Querying This Documentation
If you need additional information that is not directly available in this page, you can query the documentation by asking a question.
Perform an HTTP GET request on the following URL with the `ask` and `goal` query parameters:
GET https://support.audacityteam.org/audio-editing/changing-pitch.md?ask=<question>&goal=<user_goal>
`ask` is the immediate question: it should be specific, self-contained, and written in natural language.
`goal` is what the user is ultimately trying to achieve, the reason they need the answer. Sharing it helps GitBook give you a better, more relevant answer. A goal is most helpful when it describes the outcome the user wants rather than restating the question. For example, with `ask=how do I create an API token`, a goal like `automate deployments from our CI pipeline` lets GitBook tailor the answer to that use case.
The response will contain a direct answer to the question and relevant excerpts and sources from the documentation.
Use this mechanism when the answer is not explicitly present in the current page, you need clarification or additional context, or you want to retrieve related documentation sections.
