> For the complete documentation index, see [llms.txt](https://support.audacityteam.org/llms.txt). Markdown versions of documentation pages are available by appending `.md` to page URLs; this page is available as [Markdown](https://support.audacityteam.org/basics/recording-desktop-audio.md). Agents can also search and read this documentation through its [MCP server](https://support.audacityteam.org/~gitbook/mcp).
# Recording desktop audio
Audacity can record computer audio (including sound from YouTube, Spotify and more).
{% embed url="<https://www.youtube.com/watch?v=VB0-XfW6lms>" %}
Video tutorial for Windows
{% endembed %}
## 1. Select the loopback device
{% tabs %}
{% tab title="Windows" %}
* Click on **Audio Setup** and select **Windows WASAPI** as the Host.
<figure><img src="https://2387260374-files.gitbook.io/~/files/v0/b/gitbook-x-prod.appspot.com/o/spaces%2F-MhmBVzGzh8SctWQ6jPR%2Fuploads%2FTbUbTqZUgEguU5tk2NGx%2FAudio%20Setup%20Host%20Selection.png?alt=media&amp;token=d60a84fc-014e-42bc-8e13-8376d3064daa" alt=""><figcaption><p>Select <strong>Windows WASAPI in Audio Setup > Host</strong></p></figcaption></figure>
* Select the output you want to use (the device you're using to listen) as the input. It will be marked with a (loopback) after it's name.
<figure><img src="https://2387260374-files.gitbook.io/~/files/v0/b/gitbook-x-prod.appspot.com/o/spaces%2F-MhmBVzGzh8SctWQ6jPR%2Fuploads%2FlTjLWsG74WGgDdvPLvjF%2FLoopback%20device%20selection.png?alt=media&amp;token=9eb4b3d3-3cd9-4dcf-9bad-27f4cd0579ae" alt=""><figcaption><p>Select the <strong>loopback</strong> option for the device you want to record audio from.</p></figcaption></figure>
{% hint style="info" %}
When using the (default) MME device, you may find a virtual microphone called *Stereo Mix*, *What you hear* or similar in it. This also will record your desktop audio.
{% endhint %}
![Selecting Stereo Mix as an alternative to record desktop audio](https://2387260374-files.gitbook.io/~/files/v0/b/gitbook-x-prod.appspot.com/o/spaces%2F-MhmBVzGzh8SctWQ6jPR%2Fuploads%2Fvc7a71wUfZayCBOM7neB%2FStereo%20Mix%20Recording%20option.png?alt=media\&token=6640431c-fb77-4121-b049-6b83c4322018)
{% endtab %}
{% tab title="macOS" %}
**Note:** MacOS does not have built-in desktop audio recording capabilities. You'll need to download Soundflower to record desktop audio.
{% endhint %}
#### Soundflower
{% hint style="warning" %}
**Caution:** Soundflower is not compatible with Apple Silicon-based machines ("M1", "M2", ...)
{% endhint %}
1. Download Soundflower from <https://github.com/mattingalls/Soundflower/releases/> and follow the instructions provided there to install it.
2. Open the **Audio MIDI Setup** app (found in `/Applications/Utilities`).
3. Press the **+** button in the bottom left corner and select "**Create Multi-Output Device**".
4. In the panel that appears to the right, select **Built-in Output** and **Soundflower (2ch)**.
5. Press the gear button in the bottom left and select "use this device for sound output".\
   **Note:** If you don't set an option, you won't hear anything after completing the following steps.
6. Start Audacity
7. Click the **Audio Setup** button and set **Soundflower (2ch)** as the recording device.
   {% endtab %}
{% tab title="Linux" %}
When using PulseAudio (default for Ubuntu, Linux Mint, and others):
1. Install PulseAudio Volume Control (pavucontrol). This should be in your repository already.
2. Use the **Audio Setup** toolbar to select **ALSA** as the audio host and select **pulse** as the recording device.
   If your system uses Pulse by default, the pulse device may be called **default**.
3. Enable the recording meter by selecting **Start Monitoring**.
   <figure><img src="https://2387260374-files.gitbook.io/~/files/v0/b/gitbook-x-prod.appspot.com/o/spaces%2F-MhmBVzGzh8SctWQ6jPR%2Fuploads%2F3TRXh95ZwLCSUEEJvTtu%2Fimage.png?alt=media&amp;token=56b3e796-5919-451c-a0b0-964953acfb87" alt=""><figcaption><p>Click the Microphone icon to start monitoring the recording level</p></figcaption></figure>
4. Open **PulseAudio Volume Control** and choose the **Recording** tab.
5. In the **Capture from** dropdown, select the "Monitor" option of the playback device used by the application you want to record from
   <figure><img src="https://2387260374-files.gitbook.io/~/files/v0/b/gitbook-x-prod.appspot.com/o/spaces%2F-MhmBVzGzh8SctWQ6jPR%2Fuploads%2FxP9APUbL62lXqQpEcnLK%2Fimage%20(2).png?alt=media&amp;token=b6d33b9e-2e69-4322-9e85-a46630557d37" alt=""><figcaption><p>PulseAudio Volume Control - Select <strong>Capture from:</strong> Monitor of device</p></figcaption></figure>
6. Launch the application that you wish to record and begin playback.
7. In the "Recording" tab of PulseAudio Volume Control, drag the volume sliders so that the recording level in Audacity's Recording Meter is to left of 0 dB (-6 dB is a good level to aim for).
   {% endtab %}
   {% endtabs %}
## 2. Check if everything is set up correctly
Recording the desktop audio will record all desktop audio, including notification-pings, games, and Audacity itself (for example, other tracks in the timeline if you're using overdub). So unless you specifically want these noises, make sure to turn them off.
{% hint style="danger" %}
**DON'T use software playthrough** when recording desktop audio. Make sure it's off in the menu: **Transport > Transport Options > Software playthrough (on/off)** - The :heavy\_check\_mark:checkmark next to it must be turned off. You can turn off overdub here as well.
{% endhint %}
## 3. Record
Hit play to ensure audio is playing and then the record button to record your desktop audio.
**Ensure audio is playing first** when recording desktop audio as although WASAPI can record a silent audio stream it can’t record when there’s no audio stream.
{% endhint %}
# Agent Instructions
This documentation is published with GitBook. GitBook is the documentation platform designed so that both humans and AI agents can read, navigate, and reason over technical content effectively. Learn more at gitbook.com.
## Querying This Documentation
If you need additional information that is not directly available in this page, you can query the documentation by asking a question.
Perform an HTTP GET request on the following URL with the `ask` and `goal` query parameters:
GET https://support.audacityteam.org/basics/recording-desktop-audio.md?ask=<question>&goal=<user_goal>
`ask` is the immediate question: it should be specific, self-contained, and written in natural language.
`goal` is what the user is ultimately trying to achieve, the reason they need the answer. Sharing it helps GitBook give you a better, more relevant answer. A goal is most helpful when it describes the outcome the user wants rather than restating the question. For example, with `ask=how do I create an API token`, a goal like `automate deployments from our CI pipeline` lets GitBook tailor the answer to that use case.
The response will contain a direct answer to the question and relevant excerpts and sources from the documentation.
Use this mechanism when the answer is not explicitly present in the current page, you need clarification or additional context, or you want to retrieve related documentation sections.
