> For the complete documentation index, see [llms.txt](https://support.audacityteam.org/llms.txt). Markdown versions of documentation pages are available by appending `.md` to page URLs; this page is available as [Markdown](https://support.audacityteam.org/basics/customizing-audacity/effect-presets.md). Agents can also search and read this documentation through its [MCP server](https://support.audacityteam.org/~gitbook/mcp).
# Effect Presets
Each effect in Audacity comes with a predefined set of values that you can change and save according to suit your needs and workflow.
When you select an effect to apply to your audio (for example **Effect > Noise Removal & Repair > Noise Gate...**) Audacity will show you the effect settings window where you can change the different values according to your needs.
<figure><img src="https://2387260374-files.gitbook.io/~/files/v0/b/gitbook-x-prod.appspot.com/o/spaces%2F-MhmBVzGzh8SctWQ6jPR%2Fuploads%2FvhN6j2eryj77IKwJbRuN%2Fimage.png?alt=media&amp;token=bd8e75c4-c06a-4808-930d-34acdde48c19" alt=""><figcaption><p><strong>Noise Gate</strong> effect default settings</p></figcaption></figure>
After you find the settings that best suit your needs you can use the **Presets & settings** button to save your settings for future use:
* Click the **Presets & settings** button and select **Save preset...**
<figure><img src="https://2387260374-files.gitbook.io/~/files/v0/b/gitbook-x-prod.appspot.com/o/spaces%2F-MhmBVzGzh8SctWQ6jPR%2Fuploads%2FqNInGgXbDTliX8fDIkMH%2Fimage.png?alt=media&amp;token=b84c79e4-ed98-47d1-b124-afa5ffbd47b3" alt=""><figcaption><p>Type a name and press <strong>OK</strong> to save your preset</p></figcaption></figure>
* After saving your presets you can recall them the next time you need to apply the same effect. Click the **Presets & settings** button, select **User Presets...** and select the name of the previously save presets:
<figure><img src="https://2387260374-files.gitbook.io/~/files/v0/b/gitbook-x-prod.appspot.com/o/spaces%2F-MhmBVzGzh8SctWQ6jPR%2Fuploads%2F8x5YIvc9D3V4yCNXBO3d%2Fimage.png?alt=media&amp;token=546ab2f8-378a-45e3-97a1-423b5ba21bc6" alt=""><figcaption><p>To recall a previously saved preset click <strong>Presets &#x26; settings ></strong></p></figcaption></figure>
{% hint style="info" %}
To restore the factory default settings select **Presets & settings > Factory Presets > Defaults**
{% endhint %}
# Agent Instructions
This documentation is published with GitBook. GitBook is the documentation platform designed so that both humans and AI agents can read, navigate, and reason over technical content effectively. Learn more at gitbook.com.
## Querying This Documentation
If you need additional information that is not directly available in this page, you can query the documentation by asking a question.
Perform an HTTP GET request on the following URL with the `ask` and `goal` query parameters:
GET https://support.audacityteam.org/basics/customizing-audacity/effect-presets.md?ask=<question>&goal=<user_goal>
`ask` is the immediate question: it should be specific, self-contained, and written in natural language.
`goal` is what the user is ultimately trying to achieve, the reason they need the answer. Sharing it helps GitBook give you a better, more relevant answer. A goal is most helpful when it describes the outcome the user wants rather than restating the question. For example, with `ask=how do I create an API token`, a goal like `automate deployments from our CI pipeline` lets GitBook tailor the answer to that use case.
The response will contain a direct answer to the question and relevant excerpts and sources from the documentation.
Use this mechanism when the answer is not explicitly present in the current page, you need clarification or additional context, or you want to retrieve related documentation sections.
