> For the complete documentation index, see [llms.txt](https://support.audacityteam.org/llms.txt). Markdown versions of documentation pages are available by appending `.md` to page URLs; this page is available as [Markdown](https://support.audacityteam.org/basics/audacity-editing.md). Agents can also search and read this documentation through its [MCP server](https://support.audacityteam.org/~gitbook/mcp).
# Editing audio
This page is an introduction tutorial to editing in Audacity. It covers how to import files, making cuts, rearranging clips, and applying effects!
## Importing a file
To start editing, you need some sort of sound to edit. You can either [record some sound](https://support.audacityteam.org/basics/recording-your-voice-and-microphone.md), or import an existing sound file (for example, an MP3 or WAV) by dragging & dropping it into the project window. You can also import files via the **File > Import** menus.
{% hint style="info" %}
**Note:** To import proprietary file formats such as M4A or WMA, you need to [install FFMPEG](https://support.audacityteam.org/basics/installing-ffmpeg.md) first.
{% endhint %}
Once you have that, you will see a waveform of your sound:
![The waveform of a song](https://2387260374-files.gitbook.io/~/files/v0/b/gitbook-x-prod.appspot.com/o/spaces%2F-MhmBVzGzh8SctWQ6jPR%2Fuploads%2FJWiUYFHXXTnN9QVvMXM1%2Fimage.png?alt=media\&token=9a1431df-e846-4d06-99ea-2d99f5787c5f)
This waveform is a visual representation of the song. The larger the blue "blob" is, the louder the section. Lines standing alone ("spikes") indicate sudden and short loud sections such as clicks, snaps, claps and drum hits. With a bit of practice, you can use the waveform to quickly find your way around an audio file.
## Removing sections of a song
To remove a section of an audio file, first select the section by **clicking and dragging** in the waveform.
![A selected waveform](https://2387260374-files.gitbook.io/~/files/v0/b/gitbook-x-prod.appspot.com/o/spaces%2F-MhmBVzGzh8SctWQ6jPR%2Fuploads%2F35J0m8NxbIFCKs6xee28%2Fimage.png?alt=media\&token=94a5241f-df16-42ea-9183-c9a88d123d75)
**Hint**: You can zoom in using the ![](https://2387260374-files.gitbook.io/~/files/v0/b/gitbook-x-prod.appspot.com/o/spaces%2F-MhmBVzGzh8SctWQ6jPR%2Fuploads%2FiPK7ryh7zjxtJssk6t8M%2FZoomIn.png?alt=media\&token=60ab0053-1916-485b-87e4-1eac564cae25)Zoom+ icon, or by `Ctrl+Scroll` (`Cmd+Scroll`) to precisely adjust the beginning and end of the selection.
{% endhint %}
Once you have a selection, press `Delete` or `Backspace` to delete it.
## Moving sections of audio (clips)
Audacity supports clips, which are pieces of audio inside the project which can be moved independently. Technically, any audio you record or import already exists as a clip, denoted by the rounded clip handle bars above the waveform.
You can **click + drag** on the clip handle bar to move a clip around.
![A clip handle bar. double-click to rename, Click and drag to move around.](https://2387260374-files.gitbook.io/~/files/v0/b/gitbook-x-prod.appspot.com/o/spaces%2F-MhmBVzGzh8SctWQ6jPR%2Fuploads%2Fk1TQDX7pYxwEbFEGd5vj%2Fimage.png?alt=media\&token=20bdfc49-eee5-419a-aacd-d601858b3160)
## Splitting up clips
To split a clip into two independent clips,
1. Click into the waveform where you want to split the clip.
   **Tip:** To make precise adjustments, zoom in first.
2. **Right-click > Split Clip** (`Ctrl+I` / `Cmd+I`)
**Note:** If you select some audio instead, it will create a clip out of the selection.
{% endhint %}
## Resizing and trimming clips
To trim a clip, hover with your cursor around the **upper third** of the left or right edge of a clip:
![To trim a clip, click + drag on the upper third of the sides.](https://2387260374-files.gitbook.io/~/files/v0/b/gitbook-x-prod.appspot.com/o/spaces%2F-MhmBVzGzh8SctWQ6jPR%2Fuploads%2FoHuEVztS8Xo47NuLPYv7%2Fimage.png?alt=media\&token=59f7b782-e10e-4f7f-8f8d-7e41d413ec64)
Then **click and drag** the edge to trim the clip to it's desired length.
**Note:** Trimming is a non-destructive operation. You can un-trim a clip at any time. If you have created your clip by [splitting up](#splitting-up-clips) a larger clip, you can even un-trim the current clip until it's at the length of the old clip. If you want to permanently remove the trimmed data, you can copy the clip to another project, choose **Selected audio only** when pasting, and move it back.
{% endhint %}
## Applying Effects
Audacity supports a wide range of effects and effect plugins. These effects can be used for [Noise reduction & removal](https://support.audacityteam.org/repairing-audio/noise-reduction-removal.md) and more, and while each effect does different things, they all generally can be applied in the following way:
1. Select the audio you want to apply the effect to.
2. Go to the **Effect menu.**
3. Select the effect you want to use. Typically, a window like this will open:
   ![](https://2387260374-files.gitbook.io/~/files/v0/b/gitbook-x-prod.appspot.com/o/spaces%2F-MhmBVzGzh8SctWQ6jPR%2Fuploads%2FVBkJE76T6bwcoK7UO7yZ%2Fimage.png?alt=media\&token=319a1a08-5e28-47d2-9151-cacedd05ee0c)
4. Tweak the effect to your liking. You can click the **Preview** button to hear a short sample before applying it to the whole selection.
5. Press OK to apply the effect.
{% hint style="success" %}
**Best practice:** If you want to apply an effect to an entire track, use [realtime effects ](https://support.audacityteam.org/audio-editing/using-realtime-effects.md)instead. By doing so, you can change the effect at any point later on.
{% endhint %}
# Agent Instructions
This documentation is published with GitBook. GitBook is the documentation platform designed so that both humans and AI agents can read, navigate, and reason over technical content effectively. Learn more at gitbook.com.
## Querying This Documentation
If you need additional information that is not directly available in this page, you can query the documentation by asking a question.
Perform an HTTP GET request on the following URL with the `ask` and `goal` query parameters:
GET https://support.audacityteam.org/basics/audacity-editing.md?ask=<question>&goal=<user_goal>
`ask` is the immediate question: it should be specific, self-contained, and written in natural language.
`goal` is what the user is ultimately trying to achieve, the reason they need the answer. Sharing it helps GitBook give you a better, more relevant answer. A goal is most helpful when it describes the outcome the user wants rather than restating the question. For example, with `ask=how do I create an API token`, a goal like `automate deployments from our CI pipeline` lets GitBook tailor the answer to that use case.
The response will contain a direct answer to the question and relevant excerpts and sources from the documentation.
Use this mechanism when the answer is not explicitly present in the current page, you need clarification or additional context, or you want to retrieve related documentation sections.
