> For the complete documentation index, see [llms.txt](https://support.audacityteam.org/llms.txt). Markdown versions of documentation pages are available by appending `.md` to page URLs; this page is available as [Markdown](https://support.audacityteam.org/special-uses/info-for-system-administrators.md). Agents can also search and read this documentation through its [MCP server](https://support.audacityteam.org/~gitbook/mcp).
# Info for System Administrators
Information regarding deployment and compliance for Audacity in schools, businesses, institutions and enterprises
## Deployment
Audacity does not come with any group policies or installers intended for institution-scale deployment at this time. However:
* Audacity is distributed through WinGet. You may be able to incorporate a [WinGet config file ](https://learn.microsoft.com/en-us/windows/package-manager/configuration/)into your deploy script.
* Audacity doesn't require installation; the standalone ZIP can simply be copied anywhere.
## Compliance
### Accessibility
Audacity is largely accessible. A usage guide can be found in the sidebar; a VPAT document can be found at [audacityteam.org/VPAT](https://audacityteam.org/VPAT).
### Privacy
Audacity by default only collects minimal data for update checking and crash reporting; details can be found in the [privacy policy](https://www.audacityteam.org/desktop-privacy-notice/). Audacity's data is stored in the Netherlands; the **only personal data stored is a UUID** (which can be turned off in the preferences). This also is true for the [AI plugins ](https://www.audacityteam.org/download/openvino/)- those process all data on your own device, without sending them to some cloud server (hence why the installer downloads so much stuff).
In addition, it has an Audio.com ([privacy policy](https://audio.com/legal/privacy-notice.pdf)) integration which needs explicit user action (sign up) to activate.
### Disabling features via preferences
Both features can be turned off in preferences:
* To disable update checking, go to **Preferences -> Application** and disable the relevant checkboxes.
* To disable Audio.com features, go to **Preferences -> Modules** and disable mod-cloud-audiocom.
{% hint style="info" %}
Note: Audacity's Preferences are stored per-user by default. If you'd like to set global settings or reset the state after logoff, create a folder called `Portable Settings` in the same directory as the executable (audacity.exe). Make sure that Audacity has read/write rights.
{% endhint %}
### Permanently disabling features
You can compile Audacity from source with certain features disabled. You can download the source code from [audacityteam.org/download](https://www.audacityteam.org/download/). Compilation instructions are included within each source's BUILDING.md file. By default, no network features are enabled when compiling from source.
Note: You may also be able to delete library (.dll) files from Audacity's binary, eg `mod-cloud-audiocom.dll`. This only works for modules though.
{% endhint %}
### The paperwork option
If you need a special compliance form or contract filled out to use Audacity, please follow these steps:
1. Read through the compliance form you need filled out. You may find that freely distributed open source software is exempt from the paperwork.
2. Pre-fill the form as best you can, keeping in mind the minimal data Audacity collects. If you need help, check with your own compliance officer - In general its your organization that knows best what is or isn't permissible. Audacity's legal entity is MuseCY SM Ltd., Spyrou Kyprianou 84, 4004 Cyprus
3. Send the pre-filled form to [**privacy@audacityteam.org**](mailto:privacy@audacityteam.org).
In general, the more complete the form, the faster we can respond.
If you can, try finding a "tag-along" contract you can add yourself to. We currently have signed a Student Data Privacy Agreement with the Springfield School District No. 186 in Illinois, which other LEA can subscribe to.
{% endhint %}
# Agent Instructions
This documentation is published with GitBook. GitBook is the documentation platform designed so that both humans and AI agents can read, navigate, and reason over technical content effectively. Learn more at gitbook.com.
## Querying This Documentation
If you need additional information that is not directly available in this page, you can query the documentation by asking a question.
Perform an HTTP GET request on the following URL with the `ask` and `goal` query parameters:
GET https://support.audacityteam.org/special-uses/info-for-system-administrators.md?ask=<question>&goal=<user_goal>
`ask` is the immediate question: it should be specific, self-contained, and written in natural language.
`goal` is what the user is ultimately trying to achieve, the reason they need the answer. Sharing it helps GitBook give you a better, more relevant answer. A goal is most helpful when it describes the outcome the user wants rather than restating the question. For example, with `ask=how do I create an API token`, a goal like `automate deployments from our CI pipeline` lets GitBook tailor the answer to that use case.
The response will contain a direct answer to the question and relevant excerpts and sources from the documentation.
Use this mechanism when the answer is not explicitly present in the current page, you need clarification or additional context, or you want to retrieve related documentation sections.
