# Page Not Found
The URL `audio-editing/isolating-or-removing-vocals-from-a-song` does not exist. This page may have been moved, renamed, or deleted.
## Suggested Pages
You may be looking for one of the following:
- [Isolating or removing vocals from a song](https://support.audacityteam.org/music/isolating-or-removing-vocals-from-a-song.md)
- [Splitting a recording into separate tracks](https://support.audacityteam.org/audio-editing/splitting-a-recording-into-separate-tracks.md)
- [Using master effects & realtime effects](https://support.audacityteam.org/audio-editing/using-realtime-effects.md)
- [Speeding up and slowing down audio](https://support.audacityteam.org/audio-editing/speeding-up-and-slowing-down-audio.md)
- [Making crossfades](https://support.audacityteam.org/audio-editing/making-crossfades.md)
## How to find the correct page
If the exact page cannot be found, you can still retrieve the information using the documentation query interface.
### Option 1 — Ask a question (recommended)
Perform an HTTP GET request on the documentation index with the `ask` parameter:
GET https://support.audacityteam.org/music/isolating-or-removing-vocals-from-a-song.md?ask=<question>
The question should be specific, self-contained, and written in natural language.
The response will contain a direct answer to the question and relevant excerpts and sources from the documentation.
### Option 2 — Browse the documentation index
Full index: https://support.audacityteam.org/sitemap.md
Use this to discover valid page paths or navigate the documentation structure.
### Option 3 — Retrieve the full documentation corpus
Full export: https://support.audacityteam.org/llms-full.txt
Use this to access all content at once and perform your own parsing or retrieval. It will be more expensive.
## Tips for requesting documentation
Prefer `.md` URLs for structured content, append `.md` to URLs (e.g., `/music/isolating-or-removing-vocals-from-a-song.md`).
You may also use `Accept: text/markdown` header for content negotiation.
