> For the complete documentation index, see [llms.txt](https://support.audacityteam.org/llms.txt). Markdown versions of documentation pages are available by appending `.md` to page URLs; this page is available as [Markdown](https://support.audacityteam.org/basics/customizing-audacity/installing-plugins.md). Agents can also search and read this documentation through its [MCP server](https://support.audacityteam.org/~gitbook/mcp).
# Installing plugins
You can download various plugins here:
{% content-ref url="/spaces/klCVENFte0GRy5IqVz0W" %}
[Audacity Plugins](https://plugins.audacityteam.org/)
{% endcontent-ref %}
Most plugins get automatically activated once you install them on your system.
{% hint style="warning" %}
**Caution:**
* 64-bit Audacity can only run 64-bit plugins, and 32-bit Audacity can only run 32-bit plugins.
* Additionally, Apple Silicon (arm64) Audacity cannot run Intel (x86-64) plugins and vice versa.
* "Instrument" versions of plugins (VSTi, LV2i) are not supported.
  {% endhint %}
## Manually installing plugins
If a plugin doesn't get found by Audacity, or doesn't come with an installer, move the plugin files to one of the following locations:
{% tabs %}
{% tab title="Windows" %}
You can access the Common Files folder quickly by hitting `🪟 WINDOWS key + R` to launch Run and typing `%ProgramFiles%\Common Files`
* VST2: `C:\Program Files\Common Files\VST2` or `C:\Program Files\Steinberg\VSTPlugins`
* VST3: `C:\Program Files\Common Files\VST3`
* LV2: `C:\Program Files\Common Files\LV2`\
  **Note:** Always copy the complete .lv2 *folder*
* LADSPA: `C:\Users\<username>\Appdata\Roaming\audacity\Plug-ins\` **Note:** You can quickly access this folder by hitting `🪟 WINDOWS key + R` to launch Run and typing `%AppData%\audacity\Plug-ins`
* Vamp: `C:\Program Files\Vamp Plugins\`
* Nyquist: See below
  {% endtab %}
{% tab title="macOS" %}
All Plugins can be installed per-user (`~/Library/Audio/Plug-Ins/...`) or system-wide (`/Library/Audio/Plug-Ins/...`). In following, only the system-wide path is named
* Audio Unit: `/Library/Audio/Plug-Ins/Components/`
* VST2: `/Library/Audio/Plug-Ins/VST/`
* VST3: `/Library/Audio/Plug-Ins/VST3/`
* LV2: `~/.lv2` or `/Library/Audio/Plug-Ins/LV2`,\
  **Note:** always copy the entire .lv2 *folder*
* Vamp: `/Library/Audio/Plug-Ins/Vamp`
  {% endtab %}
{% tab title="Linux" %}
* LV2: `~/.lv2`, `/usr/local/lib/lv2` (for 32-bit) or `/usr/local/lib64/lv2` (for 64-bit)\
  **Note**: Always copy the entire .lv2 *folder*
* VST2: `~/.vst` or `/usr/local/lib/vst`\
  **Note**: Many VST effects are Windows-only
* VST3: `~/.vst3` or `/usr/local/lib/vst3`
* LADSPA: `~/.ladspa` or `/usr/local/lib/ladspa`
* Vamp: `~/.vamp` or `/usr/local/lib/vamp`
  {% endtab %}
  {% endtabs %}
## Installing Nyquist plugins
To install a Nyquist Plugin, follow these steps:
1. Download the plugin(s) in question.
2. Open Audacity, and go to **Tools > Nyquist Plugin Installer**
3. Click **Browse** and locate your downloaded plugin(s)
4. Click **Open,** then **Apply** and finally **OK**.
5. Restart Audacity.
6. The plugin should now be available in the corresponding Generate, Effect or Analyze menu.
## Deactivating and re-activating plugins
1. Go to **Tools > Plugin Manager**
2. Select the plugins or effects you want to deactivate
3. Click **Disable**.
4. To re-enable a plugin, select them and click **Enable**.
5. Click **OK** to close the **Plugin Manager** and save your settings.
# Agent Instructions
This documentation is published with GitBook. GitBook is the documentation platform designed so that both humans and AI agents can read, navigate, and reason over technical content effectively. Learn more at gitbook.com.
## Querying This Documentation
If you need additional information that is not directly available in this page, you can query the documentation by asking a question.
Perform an HTTP GET request on the following URL with the `ask` and `goal` query parameters:
GET https://support.audacityteam.org/basics/customizing-audacity/installing-plugins.md?ask=<question>&goal=<user_goal>
`ask` is the immediate question: it should be specific, self-contained, and written in natural language.
`goal` is what the user is ultimately trying to achieve, the reason they need the answer. Sharing it helps GitBook give you a better, more relevant answer. A goal is most helpful when it describes the outcome the user wants rather than restating the question. For example, with `ask=how do I create an API token`, a goal like `automate deployments from our CI pipeline` lets GitBook tailor the answer to that use case.
The response will contain a direct answer to the question and relevant excerpts and sources from the documentation.
Use this mechanism when the answer is not explicitly present in the current page, you need clarification or additional context, or you want to retrieve related documentation sections.
